-85 tpi to 96-00 vortec 350
Old Jan 6, 2007 | 06:55 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
I'm going to swap my original -85 305 tpi to 350 vortec(block and heads).
That vortec crate have 8" balancer and 168 tooth flexplate.Can I re use pulleys(v-belt exept alternator),accessory brackets,waterpump,oilfilter adapter,oil dipstick and tube from my old engine?.New engine has a plastic timing cover ,is it ok or must i chage it to steel one?
-Jari-
Old Jan 6, 2007 | 08:32 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
should be no problem. not sure about the flexplate,the '86 305 is 153, the starter should be ok with either. you'll need the intake and valve covers off the vortec as well.
what year is the vortec?
Old Jan 6, 2007 | 10:04 AM
z 28 jari's Avatar
Engine: 385
I'dont know,Yearone told only that crate has vortec block.Is there some difference between 96-00 vortec 350 blocks?
Old Jan 6, 2007 | 10:48 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
just wondering about the plastic timing cover, i would probably swap it for an aluminum one.
Old Jan 22, 2007 | 01:26 PM
z 28 jari's Avatar
Engine: 385
Forgot to ask,does my startermotor from 305 tpi work with this new 350 ,or is there problems with it?(different flexplate 153 vs.168tooth and start mounting position)
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
