V6 To V8 stuff
Old Jan 7, 2007 | 12:33 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
V6 To V8 stuff
So I know I need to swap out most suspension parts, transmission, linkages, wiring harness, exhaust, ECM, most of the computer stuff, motor mounts (obviously ) and some other stuff. But what if I just bought a trashed Z28 or Iroc-z and put all of the suspension parts, under dash stuff, computer, and trans into my car? Oh yes, and I need to know, is there a difference in the transmission for the 6 and for the 8, whats the V8 transmission called, my car has the Borg and Warner (MB1 on the build sheet) with a GU6(3.42) rear. Would that gear be too high for a V8 5 speed?
Old Jan 7, 2007 | 09:04 PM
firstfirebird's Avatar
You're asking in the wrong forum. Check the "engine swap" forum, the people in here happen to like their 6er's. I do know that your gearing will be fine even though you probably don't have posi. The bolt pattern on the V6 is 60 degrees and the V8 is 90. I believe you can change the bell housing, but don't quote me.
If you have the spare car, the best thing to do is salvege ALL the parts needed off the V8 car and move them over to the recipient.
Here's a link to where you'll find some more info...better than I can give!
Engine Swap on Thirgen.org
Old Jan 7, 2007 | 09:06 PM
Kevman's Avatar
Engine: 2004 LQ4
I like my 6er, but it's got 191000 km on it, so I'm not sure how long it's going to last as a daily driver. But sorry, I didn't see the Engine Swap board.. I was kind of hurrying..
Old Jan 8, 2007 | 12:02 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
read the sticky in the engine swap forum. That was my best reference when I put in the 305.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
