what serpentine belt do i need
Old Jan 7, 2007 | 04:08 PM
singledownloop's Avatar
to remove the power steering and air pump from this 91 caprice motor?I want to retain the air.
Old Jan 8, 2007 | 01:51 PM
David Petersen's Avatar
I ran into a similar problem when I used an aftermarket dampner and the stock belt wouldn't fit.
If you want to use a Goodyear Gatorback belt, just measure the lenth you need with a sewing or flexible measuring tape and use the following chart to get a part number.
Functional Part Number Gives You The Size Of The Belt
4 06 049 5
1st digit (4) represents a K section Poly V-belt.
2nd and 3rd digit gives the number of ribs.
4th, 5th, and 6th digit are the length in inches.
7th digit is tenth of an inch.
Part number 4060495 would be a K section Poly-V belt, six ribs wide, with a length of 49 and 5/10 inches.
More info at http://www.goodyearbeltsandhose.com/cars/gatopoly.html
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
