my 383 and summit 31x19" rad install and couple other mods
Old Jan 8, 2007 | 09:31 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
just wanted to show off my 85 trans am and get some feedback from some other fellow thrid geners
http://www.cardomain.com/ride/2211363
Old Jan 9, 2007 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you have some better pics of the radiator mounting? Not clear on what you did there.
Or maybe more descriptions of the details.
Old Jan 9, 2007 | 02:59 PM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
what did u pay for that rad?
Old Jan 9, 2007 | 06:08 PM
Car: 85 trans am
Engine: 383 stroker
i think i paid around 180 for it from summit. basically what i did to the radiator was trim the top and bottom fins off to make it sit lower to the original position. then i went to the local hardware store and purchased some rubber gasket material to insulate the metal frame from rubbing on the bottom of the radiator. then i tilted it forward to clear the hood and squeezed some round rubber stoppers to stop the bottom from sliding forward. i also removed the a/c condenser. i hope this helps some more.
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
Wade787b
Sep 29, 2015 01:15 PM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
matthew911
Aug 12, 2015 09:38 AM
