What to expect 305 -> 350, performance wise?
Old Jan 17, 2007 | 07:44 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
So were almost finished with the swap...probably actually turn the key and wonder why its not working...TODAY! (but damn its cold out!)
Anyway...so Im kinda excited...and I was wondering what type of performance gains I should expect?
It was plenty quick for me with a 305, and a shift kit...it was rock stock...as is this 350...of course it still has the shift kit in it, and Ive done the heater hose bypass mod on the TB...no other mods...
Should I expect a *truly* noticeable difference swapping a stock 305 to a stock 350?
Old Jan 17, 2007 | 09:27 AM
That would depend on what stock 305, and what stock 350.
If you took out a L69 or LB9 and put back in a 76 Nova 350 2-barrel, then you downgraded yourself from 190 HP to 165 HP but picked up some torque at low RPMs.
If you took out a LG4 or L03 and put back in a 70 LT1, then you went from 145 HP or whatever, to about 325 HP; and it won't be hard to predict what you'll feel.
"Stock" covers ALOT of ground. It is beyond meaningless to use that word by itself to describe a motor. "Stock LB9", "stock 1983 truck 350 4-barrel with the TPI on top", "stock Goodwrench phone-company-van replacement motor", those have meaning; but "stock" in a vacuum is worthless.
Old Jan 17, 2007 | 09:39 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
I think it was an LB9 305, and we just got a crate 350...with no performance options...the TPI and everything is the same as it was on the 305.
I guess it was a silly question...
Old Jan 17, 2007 | 09:41 AM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
Did you use a 350 sensors (knock and esc) and have you upgraded the fuel supply?
Old Jan 17, 2007 | 09:54 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Yes, 350 chip, sensors, fuel pump and injectors
Old Jan 17, 2007 | 10:02 AM
Does the new engine have flat tappet cam or roller?
It should be better all around on power. Should be about the same on fuel mileage as the 305 until you get use to the power and start pushing it harder.
Old Jan 17, 2007 | 10:06 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Hmmm...roller....I think...
Old Jan 17, 2007 | 10:17 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Im thinking that your going to spin the tires a little easier now
Its going to feel alot better down low. Did you do anything else while you were in there, like headers?
Old Jan 17, 2007 | 05:08 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Nope...Im on a budget here
There will be time for all that...
Old Jan 17, 2007 | 09:34 PM
I would for sure find out if it is a roller cam or not. If it isn't roller and I'm pretty sure it isn't. You will need to break the camshaft in if not bad things can happen. Hate to see you having to replace the valve train and send all the metal shavings in the engine / bearings.
Old Jan 18, 2007 | 07:30 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
The invoice says its a roller cam...heres the specs on the engine I bought:
http://www.rebuilt-auto-engines.com/...43107017706.22
Old Jan 18, 2007 | 02:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My brother bought that engine from them. It's a roller cam.
Hopefully you got 083 heads with it.
You should be pleasantly surprised.
Old Jan 18, 2007 | 03:59 PM
Depending on the cam they used, that should be more or less identical to the 350 that you would have got stock as a TPI one. So yeah, it could be A WHOLE LOT worse. Should make a noticeable improvement.
Old Jan 18, 2007 | 06:55 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Yup, 083 heads.
Old Jan 19, 2007 | 12:22 AM
five7kid's Avatar
They reuse factory roller cams as long as they aren't damaged.
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
