Ram Jet setup
Old Jan 17, 2007 | 11:23 AM
rockytrh's Avatar
Ram Jet setup
Not exactly sure if this is the right place to post this question.
This summer, or possible the next (depending on financial situations) I am doing an engine swap, and right now doing research. I drive an '88 Camaro, and it came with a 2.8L v6, which is a really small engine. Anyway, i am going to put a new crate Ram Jet 350 into it (http://www.rebuiltcarengines.com/ce11.html just a reference, not where i am going to buy it from). I also plan on putting a Ram Air hood on my camaro (as seen here http://www.gtfiberglass.com/ again, probably not where i will buy it, just a reference).
Here is my question: does anybody here know where i can find a ram air intake to use the functional hood scoop for that type of hood? I have found this: http://marylandspeed.com/product_inf...roducts_id=597 but not sure if it will work. I guess what i am trying to find is a filter box for the ram air hood shown above, but i cannot find one. Any help would be appreciated.
Old Jan 17, 2007 | 03:27 PM
RED396's Avatar
Car: 1989 IROC-Z
Engine: Was a 396 SBC, Now a 5.3l w/LS9 Cam
Airbox
The airbox is on gt's site.
http://www.gtfiberglass.com/OURSTUFF.html
Old Jan 17, 2007 | 03:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't looked at the Ram Jet crate for awhile. They've gone up in price, but SDPC sells them for about $900 less than that.
Old Jan 24, 2007 | 11:08 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Summit is way less then that too and they have great pricing on shipping.
Old Jan 25, 2007 | 11:40 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
I have found you don't have to have a different hood with the Ramjet. You can modify the stock flat hood by trimming the crossbrace above the throttle body. I put the RJ350 in a 89 Firebird and had to trim a piece the size of a baseball card and got enough clearance.
If you are going to change the hood the air box from Ramairhood.com should work and be functional.
https://www.ramairhood.com/store/scr...p?idproduct=18
Old Feb 14, 2007 | 09:17 AM
KS_TransAm's Avatar
-Bilms01-
Did you have to swap the oil pan on the Ram Jet to make it fit..?
I am interested in this swap for my 82 Trans Am...
Old Feb 14, 2007 | 11:14 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
I used the pan for my 89 since the RJ350 is a 1 piece rear main. It also comes with a windage tray mounted on main bearing bolts that will need to change also.
If you go to http://www.gilbertchevy.com/frame.ht...rformance.html
on the discussion board there in a thread specifically for thr Ramjet 350 and 502 it will give you a lot of great info they are pretty nowlegable.
cowansauto
Apr 3, 2025 12:51 PM
Stangski09
Nov 14, 2015 01:27 PM
Kenwood
Sep 11, 2015 12:50 PM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
