engine swap help
Old Jan 20, 2007 | 09:37 AM
Irocman86's Avatar
engine swap help
what do i need to get from gm to convert my 305 to 350
i have tpi with the perimter style heads
the motor is from a 92 suburban with 40,000 miles on it and its a gm goodwrench rebuild
heres what i know i need injectors, prom and knock sensor
and champhering the center two bolts on the intake please go into detail im new to this
Old Jan 20, 2007 | 12:23 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
have you used the search feature on this site? There is alot of info in here. There is a site called www.TPIparts.net ,go to it and check around.
Other than what you already know, the swap isn't hard at all. You may want to port out the intake. The 350 is going to need more air at high rpm's. If everything is stock on the 350 you should be fine though. I took a grinder and carbide bit and removed all the raised casting materials on the inside of the lower intake runners, plus a little more.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
