swap help please
swap help please
can someone give me a list of what i will need to swap my v6 1986 camaro automatic to a carbed 350 with manual? so i can print it out and start hunting
and i know that theres the sticky but i want an actual list of thing i need
and i know that theres the sticky but i want an actual list of thing i need Joined: Mar 2000
Transmission: 4L80E/4L80E
Tell you what, tell us what you think you'll need and we'll tell you whether it's complete, has things you don't need, and/or other things you'll need.
There's a sticky in the Tech Articles from the homepage that discusses EFI to carb. Between that and the V6 to V8 swap sticky, you should know everything you need.
carburated 350
power steering pump hoses and brackets
altenator and brackets
possible radiator
new exaust fer a v8
manual tansmission torque arm
5spd pedal,center consol,shift linkage
5 spd manual transmission out of an 83-92 camaro
v8 manual 5spd tach
i wont need a ecm with going with carburated right?
v8 brake line
v8 engine mounts
3 port adjustable fuel preasure regulator
oil preasure safety switch
rewire the fuel lines
the v8 front springs and sway bars
and subframe connectors
did i miss anything?
possible radiator
new exaust fer a v8
v8 manual 5spd tach
v8 brake line
v8 engine mounts
The 5 spd torque arm is the same as an '86 auto tranny (V6 or V8 - same thing).
You will need a V8 radiator. The '86 V6 radiator was small and had the connections on the wrong sides.
A carb V8 throttle cable would be easier to route, but you may be able to make the V6 cable go where you need it to go.
You won't need to change the ECM.
You will have to reroute, lengthen, and/or reterminate some wiring.
Otherwise, looks like you've done your homework.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Otherwise, check out the TGO supporters. Here's a web site worth checking also; http://www.tacreationsusa.com
Good luck
Hello, Michael
Aug 20, 2015 03:19 PM
