help lt1 ecm programming
Old Jan 25, 2007 | 10:05 AM
jrs84ta's Avatar
Car: 1984 firebird
Engine: swapping lt1
any body in the houston area know a place to program an lt1 ecm. I am almost done with my swap into a 84 firebird, but need the ecm programmed to remove the vats and emissons
Old Jan 25, 2007 | 10:10 AM
jrs84ta's Avatar
Car: 1984 firebird
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Old Feb 1, 2007 | 07:34 PM
zmack28's Avatar
swap
Im doing the same swap, I have a LT1 with elderbrock preformer heads and cam, I have not startd doing the sweap yet but i was wondering how hard was your wiring harness. did you run into probelms, and are you using teh ECM from the 87 or a ECM for a LT1? I have a ECM out of a 97 z28 and was gonna ust that....thansk for any info you can help me with, Im in San antonio.....
http://cgi.ebay.com/ebaymotors/ws/eB...4490503&rd=1,1
not sure how relayable they are but you can look into them.....
Old Feb 1, 2007 | 08:28 PM
jrs84ta's Avatar
Car: 1984 firebird
programming answers
the swap is easy the only hard thing to do is drilling a new hole for the passanger motor mount. i got the wire harness from currentperformance.com they made me a closed loop system that connects the ecm to the motor and allows it to run with out any major wireing just connect 3 wires crank signal, 12 volt power on run and start and the fuel pump wire. it cost me $550 but they can make one for you if you have an old harness for about $375. as for the programming i found some software for sale called lt1 edit, and i am going to buy that. if the motor is a 97 than it will work but if it is not than you have to program that ecm
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
