NoObie Here help please
Old Feb 7, 2007 | 12:42 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
well hello everyone i am happy to join your gang. lol
well as you can see already i try to be funny anyway.
i bought a camaro from my girlfriends fathers neighbor
he claimed he dropped a 4bbl 350 4 bolt main. with a turbo 350 trans in the 87 berlinetta.
now. i did the oilpan gasket and to my surprise there were only 2 bolts on the main bearing caps.
then i decided to check the stamped letters behind the alternator on the block. and all the letters came out to the engine being from the 70's
then i decided to check for the casting number behind the engine where the back of the engine mates with the bell housing of the trans. and to my surprise
the casting said "GM 5.0 L"
is it safe to say that its a 305??
the guy tricked the camaro out. its got full hotchkis suspension.
springs. traling arms etc.
got a b&m slap shifter.
and i just installed a flowmaster exhaust on it.
what im asking is .
how can i be 110% sure of what engine and trans i have in my car . so i can finally know what im driving
the engine in it now is carbureted. 4 bbl. rochester carb. has all factory egr piping on the stock exhaust manifolds. the air pump belt was cut off. as well as the a/c belt.
help me out
please.
thanks
walt-
Old Feb 7, 2007 | 02:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Enough of your brand of humor.
jk
Did you get the block casting # when you had your face down there? That's the real way to tell what you've got. 2-bolt mains don't mean anything. I've heard stories about that "5.0" casting not necessarily meaning a 305.
Old Feb 7, 2007 | 02:43 PM
Simply-305's Avatar
jk
well thats the thing! i checked ALLL around that area and all it said was "GM 5.0 L"
nothing else was casted on there.
thats the wierd thing. and it was on the driver side in the back of the engine . thats the reason why i beleive its a 305.
when did car manufacturers start specifying displacement with liters. instead of cubic inches of displacement.???
Old Feb 7, 2007 | 03:09 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Look harder. Get a wire brush or something. Peak behind the bellhousing flange and look for 5.0LG or 5.7LG then on the opposite flange there will be some numbers. Bring us the numbers and we will bring you peace of mind.
p.s. Welcome to the boards.
Old Feb 7, 2007 | 05:46 PM
Simply-305's Avatar
opposite flange meaning... opositr side of the engine like on the passenger side??
or are all these casting numbers on the driver side rear of the engine?
thanks again.
walt-
Old Feb 7, 2007 | 06:52 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
www.mortec.com
Will tell you everything you need to know! Even shows you locations of casting numbers.
Goodluck!
-Cale
Khamaro
May 11, 2012 11:36 PM
VelocitySc0pez
Jul 15, 2011 04:03 PM
Ictinike
Feb 2, 2011 10:14 PM
