Build a 350 or 383 ??
Old Feb 7, 2007 | 08:32 PM
Rebelhick's Avatar
Car: 86 TA w/ Recaro; 88 Formula 350
Engine: 305 & 355
Transmission: Autos
I have an 86 TA 305 TPI. The motor is tired and it needs replaced. I don't want to put money into building a 305. I can get a good 383 shortblock assembly for around $1800 or I can get a 350 shortblock for around $700. I don't really have a budget but if I can save a little cash and get decent performance then why not - my main goal is to have a good quality fun engine with the most bang for the buck. Here's my dilemma:
Do I get the 350 and use the $1,100 in price difference to put on better parts for more power from the 350 OR do I get a 383 and use your basic, no frills parts?
I'll be updating the drivetrain and suspension regardless of which motor I build so that's not a factor. I'm leaning towards the 383 but my friend is saying go with the 350 because it's more practical. Thoughts?
Old Feb 7, 2007 | 10:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The 350 and 383 use the same block, and if you have the buy a crank, then you might as well get the 383 crank, since its usually the same (or very close) price as the 350 crank.
Old Feb 7, 2007 | 10:23 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I say build a good hyd roller 350 and use most of the money to buy a really good set of heads. Just think about how much power you want to make and you will see a well built 350 is more than enough power to get the job done.
Old Feb 8, 2007 | 11:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Bang for the buck" is a difficult measure. How do you assign a "bang" value? HP? ET? General fun? If a $700 350 makes 240 HP and an $1800 3838 makes 270 HP, which gives more bang for the buck? You said "shortblock" - what heads were you planning on using?
A 350 is stretching TPI. Guess what a 383 does to TPI?
Old Feb 8, 2007 | 02:10 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Assuming you're sticking with teh stock TPI system, the 383 would be a total waste. You'll lose top end and won't get nearly the HP the motor could make (unless its a total dog). I would...
1. Go with the 350 and mild intake port work - its cheaper and will run awesome.
2. Go with the 383 and expect to buy runners, plenum, and a thrttle body. Way more overall potential, just more expense.
No such thing as a free lunch!
Ty
Old Feb 8, 2007 | 08:26 PM
Rebelhick's Avatar
Engine: 305 & 355
Transmission: Autos
I've decided to go with the 383. A HSR, a good set of aftermarket aluminum heads, and some good headers shouild wake it up. It's a little more money than I wanted to spend but a year from now I don't want to be wishing for more power. I only want to build it once and I don't want to build it as a 350and be disappointed.
Old Feb 14, 2007 | 07:36 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Have you thought about induction mods yet?
(what do you mean by HSR?)
Ty
Old Feb 15, 2007 | 12:11 PM
five7kid's Avatar
"Holley Stealth Ram".
It's a big-time induction mod.
Old Feb 15, 2007 | 12:29 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Ah - thus making the 383 actually viable. Sounds like a rippin' setup.
Jake_92RS
Jan 28, 2020 10:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
LT1Formula
Aug 20, 2015 09:36 PM
sreZ28
Aug 14, 2015 07:48 PM
