EFI to carb wiring
Old Mar 1, 2007 | 12:28 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
EFI to carb wiring
I removed the engine wiring harness from my efi car. I am going to carb.
If I get an engine wiring harness from a carbed camaro, will it plug into the fuse block where the efi harness did?
Old Mar 1, 2007 | 02:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably.
But, you didn't really need to remove all of the EFI harness. Everything you need to run the carb system is there in it. Whether factory carb or EFI, the same effort is required to go to non-computer carb.
Although the '82-'86 V8 distributor harness will plug right into a non computer controlled HEI distributor. Big deal, it still has a bunch of stuff you don't need.
To boot, the location of the alternator and AC switched between '87 & '88. If your car is '88-later, an '87-earlier carb'd harness is going to require more modifications to run a non-CC carb setup than the '88-later harness would.
Old Mar 1, 2007 | 03:04 PM
Car: 1971 Camaro
Engine: 427
Well, I sold the efi harness.
I am going to be running an msd ignition set up, as well as a small 'race' alternator. Ac gone.etc..
The car is becoming a drag car, big block swap.
Old Mar 1, 2007 | 03:12 PM
five7kid's Avatar
Custom wire it. You may want to get another harness to get the plug, but for the sake of cleanliness, run and wrap your own wires.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
stalkier
Aug 21, 2015 01:54 AM
