Can't remove accessories
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Hey guys, I've been prepping my motor to be pulled and I went to remove one of the pulley's but everytime I go to twist off one of the nuts the belt spins so I can't get it off. Anyone have any ideas?
Transmission: 4L80E/4L80E
Re: Can't remove accessories
I'll assume this is the water pump pulley.
Put a flatblade screwdriver between a couple of the other bolts while you loosen one. Don't remove any of the bolts until you have all of them loosened.
Billy Decker
Sep 4, 2015 03:46 PM
