engine swap question
Old Mar 24, 2007 | 02:20 PM
iwantiroc's Avatar
im putting a 350 carbed to my 88 z28 camaro from my old 75 monte carlo its been rebuilt and has about 16,000. what other parts will i need to complete this and will a tpi system work on that engine?
Old Mar 26, 2007 | 01:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It will work with these things to know about/work around:
1) The '75 engine has a 2-piece rear main seal. The flexplate (assuming auto - if manual tranny, change "flexplate" to "flywheel" from here on) from your '88 won't fit it. Most likely the flexplate on the '75 engine is too big (168-tooth, 14" diameter). You need a 153-tooth, 12-3/4" diameter flexplate for 2-piece rear main seal crank, which is what the '83-'85 3rd gen V8's had. Get one for that application, and you'll be fine.
2) The '75 engine has the dipstick on the driver's side. The 3rd gen V8 exhaust manifold doesn't let you install the stock '75 dipstick tube. You'll either have to bend/smash the dipstick tube until it fits; get a flexible dipstick like what is available from Lokar; or install headers, which will allow the '75 dipstick tube to fit between the header primary tubes. Guess which option I would recommend.
3) The '75 heads have all of the intake mount bolts at the same angle (90 degrees). The '88 heads have the two center intake mount bolts on each side at 72 degree angle. You can either elongate the mount bolt holes in your '88 base so you can get the bolts in, or get a TPI base for '85-'86 3rd gen, or any Vette TPI base, to mount the base to the '75 heads. But, what is really the best option, since the '75 Monte 350 heads are absolute performance crap, and the engine most likely has dished pistons in it, put your '88 305 TPI heads on the 350 shortblock - the engine will run much better with those heads, they'll bolt right to the block with no issues, they flow better than those old smogger head doorstops, they'll raise compression to a decent level, and your accessories will mount right back to the heads like they came off (although accessory mounting probably won't be an issue with the '75 heads).
4) Not all cams and TPI get along with each other. Most likely the cam in there is mild enough not to cause any problems, but a new cam & lifter set that you know will play well with TPI is a pretty good idea while you're doing everything else.
Old Mar 26, 2007 | 01:53 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: engine swap question
can buy a lokar or flexible oil stick tube summit racign and such
also you will have to block off plate the fuel pump hole in the block
if you run fuel injection then youll want ot get a camshaft for it that is ground for fuel injection and the ecm so it will run the best potential
there are alot of things to consider and to mull over here
they really changed alot from the 70s to the 80s as far as the engines go and wiring and so on
good luck
Old Mar 26, 2007 | 02:37 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
you will need to use the starter from the monte or swap the flywheels but everything else will work my 400 sb is from a 70 and i had no problems putting it in a 3rd gen with stock manifolds and i have the driverside dipstick
Old Mar 26, 2007 | 02:48 PM
five7kid's Avatar
Originally Posted by Z28guy83
you will need to use the starter from the monte or swap the flywheels ...
Easier to use the smaller flexplate and '88 starter.
Assuming the block is properly drilled.
Old Mar 26, 2007 | 08:11 PM
iwantiroc's Avatar
im sorry, i put the wrong year of my camaro. its a 85 z28
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
