?????????355 help fast??????????
Old Mar 25, 2007 | 12:45 AM
djbcrazy7's Avatar
Car: 95ta
Engine: 350lt1
Transmission: t56
Axle/Gears: 410
ill get right to the point i have an 89 camaro with a 305 tpi im looking to have a 355 built for it but i wanted to do my homework 1st...im looking to put down around 350 horse but i just wanted to make sure of everything im going to need... im pretty sure i need a chip burnt??? and bigger injectors but do i also need new runners will the stock 02 sensor work? anyone who has done this swap or knows how to do it if they could give me a quick rundown of what i need would be greatly appreciated???
Old Mar 25, 2007 | 03:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: ?????????355 help fast??????????
I take it you want to stick with TPI injection then? Or some other form of intjection? Rather than going carb?
Is there a reason to not go carb? I'm not trying to push you down the "dark path", just inquiring, since it's fairly easy that way. Depending on the cam you used, it might be your only way to go as well.
If you stick with TPI your stock O2 sensor should be fine, but you will have to get comfortable with burning your own proms. Runners and injectors as well, either some sort of stealthram type of complete setup deal, or just the runners themselves. Your call, either way it's more $ than a carb.
Old Mar 25, 2007 | 09:18 PM
djbcrazy7's Avatar
Car: 95ta
Engine: 350lt1
Transmission: t56
Axle/Gears: 410
well my plans are to use the existing tpi system with some upgrades....like some holly 58 mm downtubes and butterflies as well as lt1 injectors and bigger fuel rail as well as well as possibly getting a squirt computer system....the cam will be mild for the most part i only want to make around 350 horse out of the 355 with some vortec heads
Old Mar 26, 2007 | 08:14 AM
Looks like you need to separate facts from buzzwords.
You don't need a 58mm throttle body for a 350. The only way that will make your car faster, is by weight reduction. All weight savings will be concentrated at the driver's wallet, by eliminating part of its contents.
LT1 injectors are not appropriate for a TPI motor whose air flow requirements, which are determined by the TPI system as a whole, have not changed. In other words, if those long-tubes are on there, the stock injectors are fine. See the TB's contribution to making your car faster, by "weight reduction", just like those injectors.
Bigger fuel rails, the same deal. The stock fuel rails will feed enough fuel for ALOT more power than you're ever going to make with those stock runners on there. Once again, see "weight reduction".
Vortec heads are excellent. Unfortunately however, they are WORTHLESS without replacing the intake. Vortec is GM's trade name for "we moved the intake ports somewhere else". People will tell you about "drill the bolt holes"; that's only part of the story. The intake ports in the heads are moved so far that some intakes, TPI ones in particular, WON'T EVEN COVER THEM, much less match to them. So add to your Vortec head budget, the ONE AND ONLY Vortec-specific TPI lower intake, from SDPC ($400). Then, to get the benefit of the improved flow in the heads and baseplate, you need new runners too, such as AS&M, SLP, or Edelbrock; another $250 or whatever. That whole deal gets REAL expensive, REAL quick.
I suggest you do a little research on the TPI board on this site, and look at what people are doing that ACTUALLY WORKS. Not, what they say they're "going to do"; but, HAVE DONE, that works. And calm down about the buzzwords, that's not how to get your car faster.
Old Mar 28, 2007 | 04:17 PM
djbcrazy7's Avatar
Car: 95ta
Engine: 350lt1
Transmission: t56
Axle/Gears: 410
what would you recomend for a setup that puts out about 350 horse?
Old Mar 28, 2007 | 10:56 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
how about a good exhaust, a decent cam and some heads to match. 350hp isnt that hard to get from a l98 motor, you just have to get the right parts to match each other. your budget is gonna dictate how your gonna wanna spend your money but the tpi system is not the limiting factor at 350hp. i'mean hell if your just going cheap and easy, you can spray your motor to 350hp at the track whenever you what and leave it mostly as is. its all up to your personal preferances.
InfernalVortex
Apr 20, 2021 11:31 AM
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
