Pre-Vortec timing cover/balancer on Vortec short block?
Old Mar 26, 2007 | 11:09 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
I did a search, couldn't find an exact answer, hopefully this is easy for someone to answer!
Picked up a Vortec block for a future project.
The Vortec blocks use a plastic timing cover, crank sensor in that cover, as well as apparently a different balancer. What I'd like to do is run the steel timing cover off of an earlier roller cammed motor (L98, etc) as well as my current balancer.
Is it as simple as removing the Vortec timing cover/crank sensor/reluctor/balancer/pulley and replacing with the "older" stuff, or are there any other issues I will run into?
I don't foresee any, as the crank is the same so I've been able to deduce by reading previous posts, but want to make sure I don't need to re-think this any. Thanks!
Old Mar 26, 2007 | 11:16 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Pre-Vortec timing cover/balancer on Vortec short block?
Some times I find one cover hole missing but that's all.
Also look to make sure the water pump bypass hole is there.
Old Mar 26, 2007 | 11:44 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Water pump bypass...smaller hole underneath one of the two larger that line up with the water pump?
Old Apr 2, 2007 | 09:54 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
the timing cover from the L98 motors will work the cover bolt holes are still the same.
Fast355
Dec 2, 2016 06:33 PM
anesthes
Mar 10, 2016 10:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
