motor swap
Old Apr 8, 2007 | 08:29 PM
88ttopta's Avatar
motor swap
I HAVE A 88 T/A WITH THE 305 TBI MOTOR. IS IT ALOT OF WORK TO SWAP IN A 350 TPI FROM A GTA. I'M LOOKING FOR A COUPLE DIFFRENT SUGGESTIONS. I'D LIKE TO KEEP IT FUEL INJECTED IF POSSIBLE.
Old Apr 8, 2007 | 09:03 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: motor swap
do a search. its very well covered.
Old Apr 9, 2007 | 12:49 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Re: motor swap
If the 350 TPI is still in the GTA, I'd advise to take lots of pictures of the engine compartments, special attentions to vac lines, wires, and sensors. You can never take too much pictures. Make sure you label the wire harness. I've done TBI and TPI engine. If this is your 1st time doing this then it will dificult. Get a Chiltons book to help you remove and install the engine. Depending on how many miles are on the 350, you may want to do some work on the engine. If you plan on putting a cam or any aftermarket parts, I suggest getting the parts first so you can install them into the 350 engine while is out of the car. Installing parts later is a PITA, especially headers and cam.
Old Apr 9, 2007 | 03:35 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: motor swap
If you wanna do it faster you can re-use your TBI with your Trans Am engine. TBI setups seem to like the TPI heads and camshaft so you could see a real improvement without tons of work. You need to get some TBI injectors for a 350 from a pickup truck or turn up your fuel pressure a little to make the right balance.
This setup will keep your fuel injection
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
