motor mounts
Old Apr 14, 2007 | 06:06 AM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
motor mounts
hi my name is rick,I own a 1986 Trans-am. I'm doing an engine swap Right now i have a 305.I have a 1975 Chevy 350 4bolt main to put in my car.My question is do i have to relocate the motor mounts.Thanks
Old Apr 14, 2007 | 07:04 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Re: motor mounts
nope, she will go right in
Old Apr 14, 2007 | 12:38 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: motor mounts
Yep external dimension's are the same on the 305 and the 350 no changes necassary. Visually won't even be able to tell the engine was swapped. Good luck on it.
Old Apr 15, 2007 | 08:34 AM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
Re: motor mounts
Thanks for your help.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
