TBI-CARB...FUEL PUMP WIRING????
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
I have a TBI-CARB swap question. I searched for an hour and couldn't find a straight answer.
1. I REMOVED MY IN-TANK TBI FUEL PUMP AND NOW I HAVE AN EXTERNAL PUMP. I NEED TO KNOW HOW TO WIRE IT UP. I WONT BE USING THE COMPUTER ANYMORE BECAUSE ITS CAR'B NOW. THERES A POS/NEG COMING OFF THE PUMP. ABOVE THE REAREND THERES A CONNECTOR FOR THE STOCK PUMP. I HEARD YOU CAN TAP INTO THAT SOMEHOW??
Transmission: 4L80E/4L80E
What else have you removed?
If you kept the ECM in and the circuit that goes through the oil pressure sender, you should be able to use the stock harness back by the tank.
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Re: TBI-CARB...FUEL PUMP WIRING????
i took the ecm out. id like to have it turn on with the key but would running a switch into the interior be the smartest?
Might as well.
Just go through the oil pressure switch for safety's sake.
eightsixseven
Dec 16, 2024 01:50 PM
