Building a SBC 383
Old Apr 30, 2007 | 10:56 PM
bigpoppa08's Avatar
Car: 82 Camaro
Engine: 305 SBC Carburetor
Transmission: TH-350
Building a SBC 383
im picking up a lightly used 350 block from a friends brother and i plan to bore it .030 over and get a enginekits.com stroker kit but i would like some suggestions about the kind of cam and heads i should put on it and i want to put a edlebrock rpm air-gap manifold and 650 cfm speed demon carb and demon suggest a few specifications for the cam
thanks for ur suggestions in advance
Old Apr 30, 2007 | 11:05 PM
FiXX90GTA's Avatar
Car: 1990 Trans-am GTA
Engine: 383 Stroker HSR
Re: Building a SBC 383
Just a quick reply.
The cam should be based on your heads flow numbers, and power potential at specific lift. You want your cam to start making power when your heads do and wind out to when they stop flowing good numbers. Then really about how radical/lumpy you want the duration.
Maybe list your head type and some specs.
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
if you go with any decent size cam , a 650 probaly wont be enough, i dont like demons either
Old May 1, 2007 | 12:15 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
a 650 should be enough for a decent sized cam(under 240* and .500 lift).. i ran a 650 edelbrock on my first motor and that bastard made TORQUE all over the rpm range.. but hit a wall at 5700.. literally straight down power drop.. but i was running a 294S solid flat cam.. .525/.525 and 248/248 @.050" supposed to be 2500-6500 range.. but made power from 1200up..
one more thing, how much power you looking to get out of this?? and how fast do you want to spend??
Old May 1, 2007 | 04:27 PM
bigpoppa08's Avatar
Car: 82 Camaro
i probably want to spend about 3000-3500 dollars for parts and im hoping for something like 400 and 450 hp
so far im getting the block for 250, the stroker kit is 500, the carb is like 425, the manifold is like 210, and i was planning like 1200-1400 on assembled aluminum heads so thats 2700 and i need cam an oil pan strong pushrods and all that stuff
Old May 1, 2007 | 06:29 PM
5678TA's Avatar
Car: 1984 Trans Am
this was my first build..
350 block--$750
stroker kit--$800
EPS manifold--$140
650cfm thunder AVS--$350
milodon oil pan-- $200
ARP bolts, main studs, head studs--$300
gasket set--$80
comp cams k-kit(cam, lifters, springs, retainers, locks, timing set) plus pushrods--$400
camel back heads(ported and polished by my dad-free labor)--$30
all machine work and head assembly work--$700
timing cover--$100
thats minus headers, exhaust, clutch, accessories, filters, oil, etc, etc, etc...
total comes to $3750ish.. if my quick math was right.. theres alot of short cuts that you could take too.. you dont have to get top of the line stuff like i did.. it was an enginekits.com stroker as well.. but i got the upgraded rods, bolts and forged pistons.. you dont need all that unless you want serious power.. and you can reuse bolts, you can also get an oil pan for a 1/4 of a milodon.. 3500 is very do-able..
Old May 1, 2007 | 07:52 PM
bigpoppa08's Avatar
Car: 82 Camaro
how much power was it pushin
Old May 2, 2007 | 02:49 AM
5678TA's Avatar
Car: 1984 Trans Am
with no carb tuning other than a few screws turned, it laid down 316rwhp and 359rwtq on 92octane..
i added an edelbrock 800 afterwards and i pulled off a 12.76 @107 on a set of hard slicks.. first run ever with slicks, weak burnout (not even a puff of smoke), spinning past the tree while missing 4th gear..
from all those online hp calculators, with the 316rwhp/359rwtq, i should have running been that on a good run(no miss-shifts).. i coulda been to loooooow 12's with a good 60ft and solid shifting.. thats about 425hp-ish
Old May 2, 2007 | 08:08 AM
ljnowell's Avatar
If the only thing you are getting is a block, or if it is non-running, i would tell the friend to get hosed on the 250 for a 350. That is a crappy price.
Old May 2, 2007 | 02:25 PM
bigpoppa08's Avatar
Car: 82 Camaro
no it would be for the whole engine and it should still run and he rebuilt it about 2 1/2 years ago drove it a little and then its sat under the hood of his chevelle which hasnt moved in at least 2 years
but wut would a good price for just the block be
Old May 2, 2007 | 09:35 PM
5678TA's Avatar
Car: 1984 Trans Am
Bigpoppa08, pick up the latest issue of Super Chevy.. it should be the June 2007 issue.. there is a silver camaro on the cover with MUSCLE in big orange letters under it..
there is an article on the "cheapest 383 yet".. it is similar to the stuff i had.. enginekits.com stroker kit, ARP bolts, etc, etc.. it shows you the shortblock build and all the steps to make it happen..
GET IT
Old May 3, 2007 | 03:13 PM
bigpoppa08's Avatar
Car: 82 Camaro
thanks i guess ill have to pick that up while im on break at work tonight
Vojtush31
Oct 11, 2015 01:07 PM
Jorlain
Oct 8, 2015 01:57 AM
roysatikas
Sep 7, 2015 08:08 PM
dimented24x7
Sep 6, 2015 03:51 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
