350 Crate Engine
Old May 5, 2007 | 03:47 PM
Vatch's Avatar
350 Crate Engine
Hi guys, im looking to buy a 3rd generation camaro and Im just looking ahead alittle bit to see what kind of engine swaps I could do. (To decide if a 3rd gen is really what I want). I was looking at a couple differant 350's from a local GM Parts Store and wanted to see if you guys could tell me whether or not this engine would work:
http://www.bgcperformanceparts.com/default2.cfm
-Scroll to "Chevrolet ZZ4 350cl"
Thanks.
Old May 5, 2007 | 08:08 PM
zdc590's Avatar
Re: 350 Crate Engine
Would that engine work? Of course it would, ive seen a few people that have done the zz4 swap, from what i hear its a good motor
Old May 6, 2007 | 09:04 AM
Vatch's Avatar
Well I guess I want to know then, is what is an easy to swap 350 motor that would still give off alot of power. From what I've been reading alot of people like to swap in LS1's but they gotta rework alot of stuff to make it work. If the ZZ4 was the same way I would probably stay away from it.
Old May 6, 2007 | 12:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the zz4 is based on the tried and true chevy small block. it will bolt right into a v8 car. with a non emmissions carb, its a piece of cake. with fuel injection there is a little more work but not anywhere near a ls1, which is a totally different engine
Old May 6, 2007 | 01:28 PM
Vatch's Avatar
I see, do you think there's a better performance engine that I could put in that would require a similar level of work/know-how?
Old May 6, 2007 | 05:08 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
If you put a TPI on this, it will bring it down to 320hp. A solid engine.
Old May 6, 2007 | 05:22 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
the ZZ4 is what i was looking at as well , i also found http://www.tuffdawgengines.com/ and been doing searching and chatting with the people who bought them and what not and they love them , top quality parts , i will be getting my camaro's engine from here , i plan on going carb and not fuel injected
Old May 6, 2007 | 06:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
any small block motor will pretty much bolt right in, so you that matter you could bolt in a 1000hp supercharged small block or a 290hp street-mannered motor. but keep in mind, the more exotic the engine, the more other parts you will break and need to replace, ie transmissions, driveshaft, rear, chassis, ect.
theshackle
Sep 17, 2020 08:26 AM
xkingcodex
Feb 12, 2020 07:43 PM
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
