305-350 the beginning is near
Old May 16, 2007 | 05:57 PM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
Well i am finally about ready to swap my 305 for a 350 and i've got pics of some of the parts at
http://www.putfile.com/83-84z28/images
any advise would be very appriciated and all questions answered but i do have a qustion of my one i'm planning on putting in and taking out my motor and trans as a single piece is it adviseable to use a lift plate on the intake to do this or should i put bolts on the block itself to do this
Thanks!!
Old May 16, 2007 | 06:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know what it is about putfile, but I can't get to it through my work ISP.
I've pulled and installed engine & tranny together twice, using a tilt sling. It hits the firewall/cowl lip. The liftplate on the intake is balanced for engine-only, so that isn't going to work.
Picking up a couple of intake bolts toward the back if the engine would work.
Old May 16, 2007 | 08:03 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: 305-350 the beginning is near
you mean install a couple of bolts into the head where the intake goes and use them instead? even though my heads are aluminum? and how do you get around hitting the cowl lip? thanks
Old May 16, 2007 | 10:27 PM
five7kid's Avatar
If you use chains instead of a tilt sling, you shouldn't have any problems with the cowl. Use 2 chains/4 bolts since you have aluminum heads.
Old May 16, 2007 | 10:32 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
cool looking forward to doing this real soon I'm getting a little antsy about it (too many changes going on in this swap)
ZZ3Astro
Aug 13, 2019 12:57 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
starliner
Feb 9, 2016 08:18 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Marc Brown
Sep 28, 2015 01:40 PM
