454 in '84TA
Old May 18, 2007 | 12:26 AM
lincolnpark773's Avatar
454 in '84TA
If anyone is interested I was able to use the stock 305 LG4 motor mounts on my 454 Chevy in an 84 TA swap. I also used the stock starter with some 00 battery cables and it cranked over just fine. I used a Vette water pump and the whole thing squeezed in by about an inch using a flex fan. You guys probably already knew all of this though. That was a long time ago.
Old May 18, 2007 | 09:03 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: 454 in '84TA
how hard was the header exhaust setup? this seems to be the problem areas.
Old May 18, 2007 | 09:38 AM
Re: 454 in '84TA
The headers fit, they had an odd 90 degree bend in them and ran outside the subframes on both sides which I had running to 3" flowmasters, the one on the passenger side tucked up where the cat had been. If I had to do it all over again I'd have used shortie style headers which could probably be routed similar to the original setup.
Old May 18, 2007 | 01:52 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Re: 454 in '84TA
so what the motor specs? how she run?
MustangBeater20
Oct 29, 2022 09:20 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
