put a firebird 305 in my camaro electronics gone to hell
Old May 24, 2007 | 06:24 PM
g_wilicers's Avatar
i bought a '92 camaro rs that had its engine swaped for that of a '90 firebird formula 305 and now the engine runs like ****, but its in perfect condition, im told its the cpu, how do i fix it?
Old Jun 5, 2007 | 12:20 PM
Jeremy Le Dean's Avatar
Car: 1990 Iroc-z and 1989 Iroc-z Conv.
Engine: 350 TPI Vortec 472RWHP
Transmission: Tremec TKO
Axle/Gears: 7.625/3.73
Re: put a firebird 305 in my camaro electronics gone to hell
Hi,
if the camaro came with a 305 also I don't see what can cause the problem
1- make sure you don't have air leeks (specially on TPI engine).
2- make sure also you have the correct amount of fuel (check pressure on TPI should be 43psi or very close).
3- If the engine is stock, check the timing by disconnecting the ECM correction wire (a brown wire close to your AC can if equiped) and set it up to 6° of advance.
4- do not desperate we'll find what's wrong.
Sorry I only know about TPI engine but this could be good for TBI also.
Old Jun 5, 2007 | 12:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What engine was in the car originally?
Old Jun 10, 2007 | 01:51 AM
g_wilicers's Avatar
the engine originally was a 305 and there both TBI
jhawkeye
May 25, 2022 06:33 PM
InfinityShade
Aug 22, 2015 08:00 PM
justin57
Aug 20, 2015 07:05 PM
Amillionoh7
Aug 7, 2015 01:24 PM
MENINBLK
Aug 5, 2015 11:58 PM
