TEst Fitting the BBC
Old May 30, 2007 | 08:22 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I droped in the 427 yesterday for a test fit, mock up.
We took the heat and ac stuff out, bolted a powerglide to it and dropped it in.
It was the easiest engine install I have done! Sat right on the mounts and the motor mount bolts slid right in!
It all fit great. The tall valve covers cleared the pwer brakes as well.
I had to take the front cover off the wiper motor, but I think I can mod it to fit.
I was expecting it to bottom out my springs but it did not.( they are not stock)
I was going to sit the headers in place first, but I need to grind on the flanges to clear the head studs.
Hookers instructions says to put the motor in first.
From the look of it, it doesn't look that bad. I have heard they are a nightmare.
I might try installing them with the motor in, but it will come back out, so I might try to sit them in place then drop the motor.
RIght now, it is sitting on the stock motor mounts. I have some moroso solid, but it looks like you have to take the springs out to get to the nuts on the stock frame mounts.
I also have a set of moroso trick front springs that I plan to install, so I was waiting til then to change the mounts.
The only interference I saw as with my pan.
I am running a B&B Bracket pan, and the drag link just barely touches on the passenger side. Not a big deal, the solid mounts might raise the motor just enough to clear.
I have my jongblod hood on, and it closes. Running a Victor 454 0 intake and a 4500 carb. Looks like about 2-3" of clearance.
ANd, my drag ready wheels and tires!
Old May 30, 2007 | 03:29 PM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Re: TEst Fitting the BBC
Looks good, dude! That Z is gonna scream...
Old May 30, 2007 | 08:05 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
puttin` together a nice little package there, I`d say your off to a great start! those hookers are easy when you drop the bullet down on them but you should learn how to get`em in & out while the motor is in chassis, you`ll be pulling them out more than you expect,believe me. you running a roller or a flat tappet, what kinda trans and rear ger /tire size, wheels look good! this looks like a track only with those front runners, is it?
Old May 30, 2007 | 08:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I had Hookers, I tried putting them in with the engine still in. Took me 9 hours. It's easier with the engine out since you'll probably pull the engine a few times doing test fits until the headers are in perfectly.
Those rocker covers get dirty easily. Give them a coating of something. Pick a color of paint or give them a clear coating to seal the porous aluminum.
Have fun changing #7 spark plug
Old May 31, 2007 | 09:25 AM
Car: 1971 Camaro
Engine: 427
Thanks for the input.
Its a solid roller cam. Tranny will be a glide (has a stock one in it for mock up) 9" rear, I am thinking 4.30 gears.
The car is going to be a bracket car, but I will drive it to local cruises!
Front tires are Moroso Drag spacials.
Old Jun 7, 2007 | 10:18 AM
Car: 1971 Camaro
Engine: 427
The intake is already cleared, so I will probably clear the covers to match.
As for the #7 plug, I am removing the booster due to my gynormus cam, so hopefully it won't be too bad!
Street Lethal
Apr 30, 2019 12:14 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
