A/C during swap
Old Jun 21, 2007 | 08:36 PM
iamtheantirice's Avatar
A/C during swap
going to be swapping an LS1 into a 1991. curious about the A/C. will the 4th gen a/c fit in the 3rd gen? (compressor, evap coil, etc) i know i'll be making some edits due to the comp. location on the LS1. figured, while i'm at it, i might look into swapping a/c components. wasn't sure if they'd fit and if it'd be worth my time. also didn't know if the 4th gen computer would work with the 3rd gen compressor. i'm not looking to do an interior swap if that matters. i'd like to keep the 3rd gen interior intact.
i'll have a 4th gen donor car on site, so i'll have all the parts i could need pretty handy.
also, will it matter which version of the 91 i have when taking this into consideration? v6, 305, 350? in process of buying the 91, and if i can avoid a headache, i'd like to.
thanks
-Chris
Old Jun 24, 2007 | 08:36 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: A/C during swap
thanks
-Chris
yes sorta there is a post around here where someone used atleast the compressor, evap , dryer and hoses and modified heater box. I can't remember if the condesor was 4th gen or not but I think it was?
Old Jun 24, 2007 | 03:48 PM
Re: A/C during swap
i tried searching and yeilded no results... i guess i'll reword the search phrase and try again.
btw.. if it matters with your replies... i have my epa card and my automotive epa card, so i can buy r12.
-Chris
Frozer!!!
Jan 19, 2024 04:55 PM
greenyone
Aug 29, 2015 11:08 AM
BikeFarm
Aug 11, 2015 11:35 PM
