Knock sensor question--
Old Jul 11, 2007 | 12:53 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I did a search and didnt find a definate answer regarding what Knock sensor would work for my application...so i will see what the GURU's have to say...
Anyways I am finishing off my 305 to 350 swap and the question of which Knock sensor to use crops up. The new 350 has a haudralic Flat Tappet Cam..so I understand I need a specific Knock sensor specific for a 350 with a Haudraulic Flat Tappet cam....so which P/N or even Model/year knock sensor should I use?
Thanks in advance!
Dave
Old Jul 11, 2007 | 01:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Knock sensor question--
An L98 knock sensor should work.
Old Jul 11, 2007 | 02:18 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Thanks man,
But I have heard that the roller cam's vs hyd flat tappet need diffent types of knock sensors because one is much more "agressive" than the other.
I believe the L98 is a roller cam....any ideas on what I should use with a Hyd Flat tappet?
Thanks guys,
Dave
Old Jul 11, 2007 | 02:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Shouldn't make any difference.
Old Jul 11, 2007 | 05:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not true.
I have heard that knock sensors and solid lifters don't play well together. But, there's nothing about flat tappet hydraulic lifters that would upset a knock sensor.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
