I need the TGO experience...
Old Jul 19, 2007 | 08:18 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i am doing engine research on what will fit to see my options on direct bolt it for an upgrade to a 350 from my 305tpi. i dont want carbed or tbi. i like the look and response from my tpi... but i want more. i found this and wondered if any one thought it would fit and if mods were nessacery. i greatly appreciate any opinion in this matter. also i have a brand new Jasper 700r4 not even 1000 miles old in this beasty and i will need to know if the engines would bolt to that ... adapter kit... tranny also called 4L60.
this is one of my finds...
http://store.summitracing.com/partde...M&autoview=sku
and another...
and lastly i know this is a 6.0L 364 but i still would like to know if it fits with little or no mods...
TGO RULES
Old Jul 19, 2007 | 08:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Those are LS1 & LS2 engines. Not even close in any way to a bolt-in. Especially if you want to keep TPI.
More like the "4th gen experience".
Old Jul 19, 2007 | 08:27 PM
Re: I need the TGO experience...
any good ideas on where to look then for turn key 350 tpi...
Old Jul 20, 2007 | 09:45 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Man, you should reconsider the carbed route. A ZZ4 or ZZ383 crate engine from Summit would give you plenty of power. Just get an Edelbrock Performer RPM manifold with a decent Holley carb and a killer exhaust and you can't go wrong. Plus, the engine would cost less than half of the ones you listed above.
OR
Buy or build a decent 350 short block and install your REBUILT 305 heads on it. Use 1.94 intake valves and 1.60 exhaust valves with screw-in rocker studs. Also a good cam.
Just my 2 cents.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Johnny*G
Oct 20, 2015 12:37 PM
Linson
Sep 21, 2015 01:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
