1990 305 rs engine swap help
Old Aug 2, 2007 | 06:39 PM
Bledlok's Avatar
Car: 92 RS camaro
Needing to swap out an engine in a 1990 camaro RS. its a v8 305. (not an iroc) Well i need to find an engine for it and I was told be careful about the engine i get because the wireing may not match up. Any suggestions as to how to make sure i get a matching engine? can I look at casting numbers or is there a model or something i can go off of?
Old Aug 2, 2007 | 06:49 PM
Bledlok's Avatar
Car: 92 RS camaro
Re: 1990 305 rs engine swap help
also - what years of camaro 305 engines cloud i switch out? found one that is in an 1986. would it work? how can i tell.
Old Aug 2, 2007 | 11:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It will "work" except for the angle of the center two intake manifold mount bolts on each side. You can elongate your manifold bolt holes to allow it to work.
Are you just looking to put in another 305? If so, any '87-'92 305 will "work". No wiring issues or bolt mounting issues whatsoever.
Old Aug 5, 2007 | 11:18 PM
Bledlok's Avatar
Car: 92 RS camaro
thanks for info. Yea i'm just trying to replace the engine. No mod or anything.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
