need help plz
Old Aug 10, 2007 | 09:27 PM
xXx13lackcatxXx's Avatar
need help plz
ok i just traded my 96 sentra for a 91 camaro rs today. it has the 3.1 auto and i would like to know if its plausible to replace it with a 283? if so what do i need to do? will my current tranny work? what else if any will need replacing? how complicated of a procedure would it be? what kinda time frame am i looking at once i have all necessary parts? FYI: im not what u would call a mechanic, rather ameture actually so try to keep it in english for me plz. any help will be greatly appreciated
Old Aug 10, 2007 | 09:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome to the thirdgen.org family.
There is a "sticky" in the top section of this forum about switching from a V6 to a V8. A 283 will have some additional issues, but understand the basics of the V6 to V8 swap first.
There are some things to do to reduce the problems and time required (read: "donor car"). But, it's a task, even for the experienced - there's no such thing as a "bolt in", and it certainly doesn't apply here.
Old Aug 10, 2007 | 09:50 PM
Re: need help plz
ok ive read the sticky above and it was very helpful to an extent, it appears that this build is going to take some time. but as for a donor car u mention, im pretty sure right now thats outa the question. only reason i have a 283 is cuz my buddy gave it to me and said "this will make ur ride what u want it to be". and since i see this being a longer project than i originaly expected is there any problems i should expect out of a 3.1 with 115k miles on it?
Old Aug 11, 2007 | 12:15 AM
five7kid's Avatar
The 3.1's are better than the previous 2.8's. Just take care of the maintenance.
The engine is the least of the issues in a V6 to V8 swap. In fact, the 283 just makes it more difficult - assuming it still has stock heads, there aren't any mounting holes for accessories, they aren't made for unleaded gas, and the block will have the dipstick on the wrong side. With just the engine, you don't have any of the stuff needed to actually put it in the car - a far cry from making it what you want it to be.
inferno15
Aug 29, 2015 01:48 AM
BitchinCamaro
Nov 28, 2001 01:51 PM
Amrish
Nov 9, 2001 11:33 AM
Amrish
Jul 16, 2001 02:16 PM
