oil pressure sensor
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
oil pressure sensor
are 305 and 350 oil pressure sensors the same? took out my 305 in my 82 ta and sold the motor before realizing some parts I needed. so I got a new oil sensor but I can't seem to figure out where it goes? plug above the oil filter? if so the plug is too big on this 350? any help, thanks
Transmission: 4L80E/4L80E
Can we assume this was/is a carb'd car?
Should be behind the intake manifold, kind of beside the distributor. Probably had an elbow and length of tube to get it away from the intake.
You need to match the sensor to the oil pressure gage range, otherwise no different between 305 and 350.
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
