A/C Compressor Diode needed in LT1 Swap?
Old Sep 4, 2007 | 10:28 AM
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
I'm look for a little information to finish up my LT1 swap. I stuck the motor into an '83 v6 body. The existing connector has the old style blade type connector (non weather pack/tight) where the wires exit this connector there is a diode see link here for a wiring diagram.
The scematic comes from https://www.thirdgen.org/forums/ltx-...ing-lt1-c.html second entry.
Is this diode needed for the 95 model LT1 compressor?
Does the order the wires are connected to the clutch matter?
What is this diode for?
Thanks.
Old Sep 4, 2007 | 12:36 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: A/C Compressor Diode needed in LT1 Swap?
The diode is there to suppress (short) the high voltage spike that occurs when the clutch coil (or any coil for that matter) is released. The spike can cause electronic component damage.
Last edited by TexasSilhouette; Sep 4, 2007 at 12:37 PM. Reason: Corrected my crappy typing
Old Sep 4, 2007 | 12:49 PM
tom camaro's Avatar
Car: 83 Camaro
Thanks for the information. We have answered two questions
Diode needed - YES
Purpose of Diode - eliminate high voltage spike
Do you know if GM changed the size/type of diode from 83 to 95?
More importantly do you know which size/type of diode will work with a 95 model compressor?
Old Sep 4, 2007 | 01:12 PM
Engine: 350 SBC TPI
I suspect any >12V, 1watt or greater diode will do the trick. Not so much a GM spec as a selection of adequacy. Too, be sure to install it in the correct direction else it is a dead short.
Old Sep 4, 2007 | 02:29 PM
tom camaro's Avatar
Car: 83 Camaro
Does it matter which wire goes to which pin on the compessor clutch as long as the diode is installed properly?
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
