i need an answer quickly if possible...moving to florida friday...lol
Old Sep 8, 2007 | 08:28 PM
black84z28-4spd's Avatar
ok....here is the issue....my car is an 84......i transplanted a 91 305 tpi motor in the car....the motor is now set up for carb...now the issue i just stumbled upon is the alternator.....the 84 95 amp alternator has a plastic white connector that plugs into the rear with a main brown wire and a red one coming out to the rear where the nut fastens it....the 91 alternator is different plug and the same brown wire and a red one just like that.....how do i make this work....does it work just like the older style or do i need to do something special with this .....if anyone can point me in the right direction i would greatly appreciate it!!
Old Sep 8, 2007 | 11:33 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: i need an answer quickly if possible...moving to florida friday...lol
if the 91 alt has the same color and size wires just a different shape connector then splice the wires to there matching set.
Old Sep 9, 2007 | 04:26 AM
the 84's are a lil smaller while the 91's are thicker....but i wanna know how the wiring actually hooks up
Old Sep 9, 2007 | 11:41 AM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
brown wire is for the gauge/idiot light red is your reference signal (it's what turns on the alternator) if my memory is correct
Old Sep 9, 2007 | 03:55 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Most auto electric stores actually sell an adapter plug for about 5 bucks. Ask around and find the shop that still rebuilds starters and alternators for farmers and truckers. They usually have the plugs in stock.
Old Sep 10, 2007 | 12:49 AM
ok according to chiltons.
on the 84 the brown goes to your gauge, the small red goes to the junction block, and the large red goes to the batt + terminal(possibly at starter)
on th 91 the brown goes to gauge, the small red goes to junction block, the large black/red goes thru starter to batt + terminal.
Old Sep 17, 2007 | 11:06 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
just use the alternator off the old moter....that way the plug is the same
Old Sep 24, 2007 | 04:15 AM
the old alt is a 95 amp unit whereas the 91 is a 120 amp unit to support the extra wiring for the TPI.
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
