Help identify...
Old Sep 16, 2007 | 03:17 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Help identify...
I believe there was an engine swap in my car.. We were told it was just rebuilt but it may be from a different car... In our repair manual it says valve covers will have center bolts.. mine doesn't... It has the bolts on the edges... So then its either a different year or its got different heads on it. Using the manifold numbers can you find out what the engine came out of? if not anyway to find this out?
Old Sep 16, 2007 | 03:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Help identify...
Check the casting numbers on the heads to see what they are. The numbers on the block might also be interesting. Does it have TBI or TPI on it now?
Old Sep 16, 2007 | 03:25 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
TBI. Were are the two casting numbers located at?
Old Sep 16, 2007 | 03:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The head casting number is under the valvecovers. The block casting number is behind the driver side head.
http://www.mortec.com/location.htm
Old Sep 16, 2007 | 04:26 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Soo your saying its a PITA to find....
Old Sep 16, 2007 | 04:27 PM
Stevo's Avatar
Car: Pair of 92 Z28s
use a mirror and some light.
phyzik
Aug 11, 2010 04:10 PM
firebirdta84
Jan 25, 2007 02:14 PM
