oil cooler
Old Sep 16, 2007 | 05:16 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
oil cooler
I'm swapping a 305 TBI for a 350 TPI do I actually need the oil cooler?
I don't have the radiator from the donor car.
And if I done, do I need the machinist doing the block, do anything different to it so everything will work right? It is bored .30 over now.
thanks a bunch
Old Sep 16, 2007 | 05:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil cooler
You could leave it off if you want, there are no differences to the block. There were hundreds of thousands more 350s made without an oil cooler than with one.
Old Sep 17, 2007 | 02:09 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: oil cooler
just have the machinist install a regular filter mount.
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
