3.1 V6 MPFI to 5.0 V8 TBI
Old Sep 10, 2007 | 09:54 AM
WhteRbt's Avatar
Car: 1982 Firebird Trans Am
Engine: 5.0 l V8 (LG4, with L69 specs)
Transmission: TH200C
Axle/Gears: Posi 3.23 Discs
Hello Guys,
I want to swap my 92' V6 to a V8 TBI from an 91' Firebird V6. Which things do I need? I have the engine, the ECM, the complete engine harness, the instrument gauges (speedometer, tachometer) and a new transmission on my list.
Will the 3.1 MPFI fuel pump work with the TBI?
Thanks a lot,
Marcel
Old Sep 10, 2007 | 12:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'll need exhaust and the engine mounts from the V8 car. The radiators should be the same. The V6 fuel pump should be fine.
Oh, the V8 hoses, belts, throttle cables, fuel lines (only from the frame to the engine), air cleaner.
Old Sep 11, 2007 | 02:01 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: 3.1 V6 MPFI to 5.0 V8 TBI
fuel pump is fine but you will need to reduce pressure from 44PSI down to 14PSI.
Old Sep 11, 2007 | 02:05 AM
darkride86T/A's Avatar
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
You will also need coil springs for a V-8 F-Body.
Old Sep 11, 2007 | 02:41 AM
WhteRbt's Avatar
Hey guys,
thanks a lot! I am very happy that the fuel pump and the radiator are ok for this engine...
I've got another offer last week, now I am confused what I should do. I could get a 350 cid block completed with headers, Edelbrock Performer intake, Holley carb. Casting numbers were 3970010 for the block and 333882 C87 GM40 for the cylinder heads. The engine runs (not fine, but it runs ) and is still mounted in an 86' Firebird V8.
Any suggestions? As I understand, after a swap to carb I could remove all the ECM stuff, but what's about my speedometer, tachometer, cruise control, etc.?
Thanks a lot, guys!
Marcel
Old Sep 11, 2007 | 11:55 AM
five7kid's Avatar
Block is okay, heads are junk.
Whether you can eliminate the ECM depends upon emissions laws you have to observe.
Old Sep 12, 2007 | 11:46 AM
not sure what emissions regulations you have to follow in Germany.
Old Sep 14, 2007 | 03:20 AM
WhteRbt's Avatar
Hey guys,
thanks a lot. Please forget everything I said about the last offer (350 cid block). I will go with the TBI, but there is a problem, no good engine is for sale these days.
The only offer I got is from an G20 van. It's a 350 cid engine with TBI - is this recommend and will this engine also work in the F-Body? If yes, what thinks do I need? 350 engine, 305 harness, 350 ECM and chip (and the other things mentioned above, of course)?
I don't know how hard the emissions regulations in Germany are compared to the one in the US, but I want to keep it looking original in the engine bay. Of course, there must be a catalytic converter, too.
Thanks a lot,
Marcel
Old Sep 15, 2007 | 12:03 AM
you could take the engine from the van and just swap the longblock, then you would have the 350 and nobody would know unless they dug really deep to find the casting numbers.
Old Sep 17, 2007 | 07:15 AM
WhteRbt's Avatar
Hello,
so the 350 would work with the stock TBI stuff? I will keep that in mind.
I got a lot of offers this days, but there is no TBI out there... Another plan is to buy the LG4 block and mount the TBI intake, TBI unit and use the TBI ECM and engines harness - thios should be a direct swap, I am right?
Thanks a lot, and I am sorry about the confusion... good V8's are rare here in Germany...
Marcel
Old Sep 17, 2007 | 02:15 PM
yes the 350 block will work with the 305 TBI manifold.
L1992RS
Oct 17, 2013 06:20 AM
L1992RS
Aug 9, 2011 08:32 PM
Jonboy2312
Feb 24, 2008 04:54 PM
cmro92_rs305
Dec 20, 2004 07:01 PM
