Old Sep 16, 2007 | 07:35 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
I am looking to do an engine swap in my '92 firebird. It currently has a 305 tbi. I would like to be able to put out around 350 rwhp or more. I would like to keep it EFI and not carb. But i dont want to make it very complicated by having to burn chips. Tho i was thinking about building a blower motor for the car or maybe swaping in an LT1.
Just looking for thoughts from you guys on what would be the most cost effective way of doing it with out really making this project any more complicated than it needs to be. I would like to be able to just bolt in a motor with little problem and not having to worry about my PCM. I know there is alot of posts out there on similar questions so i will say sorry in advance.
I do have alot of chassis mods and a fully built rear end and a bullit proof tranny so all that i have left is a motor
Old Sep 17, 2007 | 02:02 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Engine Swap
your HP ratings and such are easily atainable with a simple longblock swap. you can swap the injectors to a higher lbs rating without changing your ECM, get a plugnplay chip which goes between the ECM and harness and your all set.
Old Sep 17, 2007 | 02:40 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Engine Swap
What "plug-n-play" chip is that? Where can I get one?
I'm skeptical because I have been down this road. I think if you get an LSx engine with the matching PCM you might be better off. I have only seen those sandwiched in programmers go in Ford products between the ECM and harness. I seriously would like to know where to get those...
Old Sep 17, 2007 | 05:40 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Re: Engine Swap
Where can i find one of those plug-n-play chips that would be very helpful and how much would one of those things cost me? so if i got one of thouse, I would be able to run a fully built 350 motor with roller rockers and cam. would putting a TBI from a 454 help?
Old Sep 18, 2007 | 07:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've seen a guy chase issue after issue when using a "piggy-back" chip, all of which went away when he pulled that thing out and tossed it where it belonged.
Get over your phobia about burning chips. It's the only way to do it right.
The answers to every one of your questions are on the TBI forum.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
