ENGINESWAP 305TBI TO 350TPI WITH T5
Car: 92 RS// Z28
Engine: L98 350TPI
Axle/Gears: 3.23 Borg Warner 9 Bolt
I have swapped an89irocz5.7tpi auto into a 92rs camaro with a 305 tbi with a standard swapped over engine harnesses and ecm but not under dash harness car will not even turnover both cars has the vats system on them need to figure out what wires need to be hooked up to start please help?
Transmission: 4L80E/4L80E
There is a VATS tech article linked from the thirdgen.org homepage.
Car: 92 RS// Z28
Engine: L98 350TPI
Re: ENGINESWAP 305TBI TO 350TPI WITH T5
YEAH I LOOKED AT THE TROUBLESHOOTING ARTICLE AN ELIMINATED THAT THE RESISTANCE IS CORRECT BUT TRYING TO FOLLOW THE VATS SCHEMATIC ON THE OTHER PAGE DOES NOT MATCH MY IROCZ WIRING IM TRYING TO LOCATE THE VATS MODULE. THANKSJB
1989formula5.7l
Aug 15, 2015 11:35 AM
