v-belt to serpentine
Old Sep 23, 2007 | 02:55 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Im putting my l98 out of my iroc into my new 84 z28 that has v belt how hard is it to put the serpentine setup in the 84?
Old Sep 23, 2007 | 03:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: v-belt to serpentine
Its not hard, you just need to take everything from the L98 car with it... take the alternator (its a different case style anyway, you'd have to), the crank pulley, the water pump, and the power steering assy. It should all swap into your '84 without too much trouble.
Old Sep 23, 2007 | 03:10 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
does the power steering pump lines from the 84 will hook up to the 89 power steering pump?
Old Sep 24, 2007 | 11:00 PM
Air_Adam's Avatar
I don't see why it wouldn't....?
Old Sep 29, 2007 | 03:51 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
If you are swapping the motor into the 84 leave it just like it is and drop in. are you using the tpi or going carb (or using the crossfire or a factory carb setup)? if you are going tpi then then leave the wiring on there and remove from the bulkhead.
Galaxie500XL
Feb 1, 2020 04:53 AM
evilstuie
Jan 9, 2020 08:29 PM
jrdturbo
Mar 31, 2016 02:58 PM
codeysabatini
Nov 10, 2015 04:07 PM
evilstuie
Sep 24, 2015 02:31 AM
