V6 for a V6 swap
Old Oct 17, 2007 | 04:55 PM
break85's Avatar
Car: 1988 rs camaro
Engine: v6
Transmission: 5 speed
V6 for a V6 swap
I wanted to know if anyone has done a 2.8 v6 for a 4.3 v6 vortek swap. If so how hard was it and if not how hard would it be. I have a s10 blazer I am going to part out but the motor is strong and I want to put it in to my camaro. Let my know what's up about it I would really like to it thanks for your time.
Break
Old Oct 17, 2007 | 09:16 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: V6 for a V6 swap
This has been done a few times. Just search the engine swap forum.
You need a V8 belhousing for your 5 speed to match up. It's best to use the V8 transmission as well.
Your 4.3 motor mounts don't line up properly and you'll have to modify a few holes in the crossmember to get them to fit.
I have not seen a successful wiring job done to run the 4.3 fuel system.
Good luck!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
