350 swap and rear end
Old Oct 18, 2007 | 11:39 AM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
i wasnt sure where to post this but im putting a 350 in my camaro that making over 300 hp and i was wondering if it would be smarter to just get posi in my current rear end or to swap in a 93-02 rear end. Any ideas or comment would be much appreciated.
Old Oct 18, 2007 | 11:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 350 swap and rear end
What's the car's purpose: track, daily driver? I run an OE 10-bolt with limited slip behind my 350/330. I've experienced no problems with it as my DD.
JamesC
Old Oct 18, 2007 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The 4th gen rears are identical to the later 3rd gen rears except for the width.
If you don't have posi now, then get a carrier for the later 28-spline axles, and aftermarket 28-spline axles. Weld the tubes to the center housing, put a support cover on it, and you'll have a rear that is just as strong (perhaps slightly stronger, since the axles are shorter) than a 4th gen's, and won't have to mess with the 4th gen's backspacing issues.
Old Oct 18, 2007 | 10:18 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
JamesC
im gunna use the car as a daily driver and i might run it at the track every once and a while just to see what it can do
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
