LS1 Conversion price lists here
Old Oct 23, 2007 | 11:24 PM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Saw alot of ppl asking for price list etc so i thought id put together a parts list of the known parts that are needed for the swap
www.Hawksthirdgenparts.com
LS1 CONVERSION
Ls1 motor mounts: $85 (sophn)
Ls1 motor mounts and trans crossmember: $195 (sophn)
Trans crossmember auto or 6 speed: $115 (soph) "the sophn crossmembers are know for getting in the way of fabricated y-pipes"
Electronic to mechanical spedo box: $299 (1989 models and earlier)
Fuel pressure regulator: $159.95
Ls1 swap fuel line kit: $249
Ls1 torque arms wich include trans crossmember: $395 (auto or 6 speed)
Ls1 fuel pump: $189.99 (can keep stocker but not recommened on v6 change overs)
V6 CARS
youll need too upgrade too front V-8 springs are yours gonna bottom out alot price varys.
ELECTRICAL
Theres a few ways too go painless sales a ls1 kit for around $589
are you can do your own splicing also im sure theres more pre made out there hawks will do it for $995
COOLING
Ive heard you can run the stock radiator and fan but i think it would be rise too step out too a dual fan setup and youll need a coolant bypass thats not too expensive.
FUEL
if you buy the fuel regulator and fuel line kit you should be able to use the stock lines no problem. if not you have too get an fitting etc etc wich can get expensive
OTHERS STUFF
You can cut down price by fabricatting your own trans crossmember try too fab out fuel line stuff (i wouldnt recommend it pay the extra money too be safe dont blow you and your car up) those are the main parts youll need thou so add that stuff up and thats about the amount ull be spending plus your engine. this is only from one website ill do more searching and add other prices soon
Old Oct 27, 2007 | 08:41 PM
LORDCRETH's Avatar
Car: 1998 Corvette Conv.
Engine: 5.7l
Transmission: 6-speed
Re: LS1 Conversion price lists here
Thanks.
okfoz
Mar 9, 2017 02:35 PM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
