ignition problems--still
Old Nov 4, 2007 | 07:20 PM
RArnold's Avatar
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
I have been fighting an intermittent miss in my swapped-in 350 into 84 camaro. got rid of the cc-carb and distributor,....complete new ignition system, but I have a miss that shows up in some cylinders more often than others, watching a hand-held plug firing indicator......when doing away with the cc-stuff, is it still ok to use the original harness plugs for the distributor ??? or does it have to be re-wired seperately.......I have disconnected the tach wire, no change, changed cap rotor & wires, no change,...tested the coil and module and they test fine.....starts easy when warm (choke not adjusted when cold)...........need help........
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
