400 sb question
Old Nov 6, 2007 | 04:04 PM
oldrebel18's Avatar
400 sb question
hey everyone, i'm new to the forum's and really new to the "muscle" car scene. i built a tuner a few years back and now want something new. i plan on dropping a 400 SB in an 83 camaro. i had a few questions about the 400.
It is a SB 400 4 bolt main. standard bore. the motor has a 350 horse RV cam in it. the guy told me that it has 350 sb heads steam drilled. also the tranny i will be going with is a 350 turbo with a shift kit?
ok so my first question is what does everyone think of that setup so far???
i want to really build a quick/cheap car i can take to the stip. i want to be in the 11 second range, and dosn't have to be all motor but would prefer it to be.
so my next question is what would everyone change/add to get the 400 to run 11's all day at the track??
Old Nov 6, 2007 | 04:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 400 sb question
There's no useful information to comment on the setup. "SB 350 heads" and "350 horse RV" cam are meaningless.
Old Nov 6, 2007 | 04:08 PM
Re: 400 sb question
The heads and the cam.
Old Nov 6, 2007 | 04:39 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: 400 sb question
Vortec heads and a cam could get you into the 11's with with nitrous.
Old Nov 6, 2007 | 07:38 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 400 sb question
I got a friend's 90 firebird with a 400 sbc into the 12s on the motor with ported L98 heads and a big cam. It was the dreaded Performer RPM grind that sofakingdom hates... with a 750 Carter AFB and 1 3/4 SLP headers (expensive) at first until we monkeyed with the TBI in a few big ways.
Getting into the 11s from there I would guess would mean deep gears (4.56? probably) and bigger cam with better heads. I'm not sure vortecs could get you there. I think they probably run out of potential on a 400 before you hit the 11s.
Old Nov 6, 2007 | 09:11 PM
Engine: 400
Re: 400 sb question
I run vortecs on my car. I've ran a 12.8 @ 108 so far. I've yet to get a good launch down as my 60' is still 1.887. I know if I ran roller rockers and an electric water pump and 3.73s in the rear I could go lower 12s. On nitrous I would imagine you could go 11's no problem.
The build I went off of made 430hp and 525ftlbs of torque. With a light enough car you could easily go 11's.
A buddy of mine said one of his friends ran 11.7 on a vortec headed 400. He's a real trustworthy guy, but in this game, I don't believe it till I see it. But it's definitely possible.
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
