Swapped in an old sbc, non computer motor and lost the kickdown?
Old Nov 13, 2007 | 12:08 PM
86Pontiac's Avatar
Buddy just got an 86 firebird(could be 85, not sure). It now has aearly 70's 350 in it and it's backed by a 700r4. Anyhow, motor runs great but the transmission will not kickdown. Would this have anything to do with the motor swap?
I know the transmission is lockup type and is partially computer controlled. Now I don't know if either would anything to do with it or not. Ive seen many of these setups yet have never heard of this happening.
Adjusting the TVcable does nothing
Edit-We know for sure the transmission did in fact kick down when it had the 305
Old Nov 13, 2007 | 12:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Swapped in an old sbc, non computer motor and lost the kickdown?
What do you have for an induction system?
Old Nov 13, 2007 | 12:31 PM
86Pontiac's Avatar
It's a holley 4 barrel. Not sure what size though. I tried telling him get a quadrajet but that was a no-go
vacuum advance is hooked up by the way. Just in case you were wondering
Old Nov 13, 2007 | 12:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You've probably got the wrong bracketry to give you the proper TV cable geometry.
Old Nov 13, 2007 | 12:40 PM
86Pontiac's Avatar
it's got the factory bracket on it. There's no major slack on the tv cable. It's got the same tension and is set just about exactly how my 86 grand prixs cable is. Now I know not all require the same settin. I was just mentioning that for reference.
We even pulled it out some and still no kickdown. Only difference that made was a super soft shift
Old Nov 13, 2007 | 12:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Exactly. The factory bracket is for a Quadrajet with a 700R4-specific throttle arm, on a factory manifold. You don't have any of those things anymore.
Old Nov 13, 2007 | 12:50 PM
86Pontiac's Avatar
So how would I go about finding the correct bracket?
I really don't understand with being the wrong bracket, what exactly is/isn't happening
Old Nov 13, 2007 | 01:03 PM
http://www.tvmadeez.com/article/index.php
They have all the parts you need on their front page.
Old Nov 13, 2007 | 05:06 PM
86Pontiac's Avatar
so which one does he need? also, isn't there a way to just make something yourself?
Is the bracket that is on it now partially pulling the cable or what exactly happening
Old Nov 13, 2007 | 05:13 PM
Your problem probably isn't the bracket.
Did you go to the home page and look at all the linkage pieces?
Note that the cable MUST move some specific distance from idle to WOT; and MUST move more during the first half of the throttle shaft travel, than the last half. Most carb linkage that comes on off-the-shelf carbs isn't long enough to move the stud far enough from the centerline of the shaft to sweep the stud through a long enough arc during its travel. They usually need an add-on piece.
What kind of carb is it EXACTLY? You should be able to find it that way. If it's available. It might require getting some kind of carb that has the right linkage to accommodate the right add-on piece.
Old Nov 13, 2007 | 05:17 PM
86Pontiac's Avatar
Not sure on which holley it is exactly. I don't know Holleys so I have no way of telling
Old Nov 13, 2007 | 07:05 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
if its a 4150 or a 4160 series, parts 20-95 and 20-121, with proper TV readjustment will get you your double kickdown detent shifts, assuming everything else is in working order as before.
Old Nov 14, 2007 | 06:08 AM
"4150" and "4160" is mostly useless to somebody that doesn't know Holley carbs; those numbers aren't on the carb any where, and don't tell ANYTHING about the linkage, in any case. Those are "model" numbers, which only tell in a vague way how the carb is built.
The number you need is the "list" number.
Old Nov 14, 2007 | 07:14 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
it isn't a 4150 or 4160 as he said "vacuum advance is hooked up by the way. Just in case you were wondering" so it is vac secondary carb. 4150 is dbl pumper and I never used the 4160 series but I think they are single feed version of the 4150 correct me if I am wrong.
Old Nov 14, 2007 | 08:28 AM
www.holley.com
Vacuum advance has nothing to do with vacuum secondary. Manual secondary carbs have a vacuum advance connection to work the distributor, same as vac sec carbs.
4160 = square-flange 4-bbl with secondary metering plate
4150 = square-flange 4-bbl with secondary metering block
You can convert a 4160 to a 4150 by buying the metering block kit... comes with a longer transfer tube.... doesn't change the carb linkage or the number of fuel feed inlets.
Both "models" have been produced in an endless array of CFM sizes, linkage styles, choke types, and other variations. That number is USELESS as to trying to figure out what linkage piece to buy.
The number you look up things like that is the "list" number, as posted above.
AFAIK the numbers Tobias posted will work on MOST newer GM and universal carbs; not all; not older ones; and not Frod or Chrysler ones.
evilstuie
Jan 9, 2020 08:29 PM
midge54
Jan 29, 2017 07:00 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Wesly_66
Aug 26, 2015 09:55 PM
jharrison5
Aug 19, 2015 05:53 PM
