What motor do i have??
Old Dec 1, 2007 | 11:09 AM
88z28350's Avatar
This is weird, i got the numbers off of the block and the engine code or whatever its called is V0625CLD and i looked it up and it says its a 77' 350. But right under it is part of the vin and it is 1ML197731, which is a 91' camaro 305. The only thing i can think of is maybe whoever did this swap engraved that vin on there because the engine code looks more authentic than the vin. Any ideas???
Old Dec 1, 2007 | 11:48 AM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Transmission: 700R/700R
Axle/Gears: 3.42 Posi/3.27 Posi
Re: What motor do i have??
Here is what I came up with on youre suffix code.
CLD 73 350 Corvette 250 L-82 T-H 400 4-Brl
CLD 74 350 Corvette 250 L-82 T-H 400 4-Brl
CLD 77 350 Corvette 180 L-48 4-spd 4-Brl
CLD 91 305 Pontiac 170 L-03 700R TBI Firebird
CLD 91 305 Camaro 170 L-03 700R TBI
Old Dec 1, 2007 | 02:56 PM
Forget that number.
Look at the casting number of the block instead. That will tell you INSTANTLY what size motor it is.
Looks to me like there's exactly zero chance that it's anything other than exactly what belongs there; namely, a 91 L03.
Old Dec 1, 2007 | 03:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since GM used the same suffix code over a few different years, you can't always get 100% information. Fortunately, a casting number can distinguish between a small bore 305 block and a 4" bore block. Once you know what the bore is, you can use the suffix number to determine what the engine originally came from.
Sound like you have a factory L03 since the last part of the VIN number matches the car. I doubt someone would hunt down a CLD 350 corvette block then restamp the 91 third gen VIN into it.
Old Dec 1, 2007 | 07:01 PM
88z28350's Avatar
Thanks for the info, so i guess i so have the 305. The guy i bought it from swore it was a 350 but i guess he was just trying to get rid of it
Old Dec 1, 2007 | 08:10 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Well, does the engine compartment look like a swap has even been done? Look for things like misplaced wires, basically anything that looks hacked together. Also, if your motor is TBI it really wouldnt make sense for someone to swap and older carb 350 to a LO3 injection setup. They would usually just look for the LO5 I would think.
Old Dec 4, 2007 | 06:08 PM
88z28350's Avatar
well i know it was swapped because my car is an 88 and there is unplugged wires everywhere. the computer was removed and the fuse box looks all bootlegged. But yeah it is carbd and thats what the numbers are on the block. it has the edelbrock 1406 carb. so i dont know lol
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
