L03 to L05?????
Old Nov 29, 2007 | 08:28 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
L03 to L05?????
I can get a 350 tbi out of a blazer for cheap, i know the owner and he's had it rebuilt it only has about 40,000 on it. Its out of a 1987 Blazer, will it bolt up just fine? Also if i was gonna buy headers for it do i buy headers for the blazer or for a 350 camaro? b/c i know the blazers engine bay has alot more room and will not fit the headers in the camaro.... i guess waht i'm asking is will camaro headers bolt of to the 350 out f the blazer? Can i also buy vortec heads and stuff for it too? Thanks
Old Nov 30, 2007 | 07:37 AM
v10viper04's Avatar
Engine: LT1, L99
Re: L03 to L05?????
actually i can get the 350 for a trade so anyone know if all is the same? can i use camaro 350 parts on the 350 out of the blazer?
Old Nov 30, 2007 | 09:36 AM
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Re: L03 to L05?????
The 350/305 stuff is all interchangeable.You'll need to get headers for the camaro. If your going to buy the newer vortec iron heads be aware that the intake bolt pattern is different and your TBI intake isn't going to bolt up.
I think edlebrock makes a Vortec TBI intake.. if they don't then I'd get the carb style vortec intake and use a Trans-dapt adaptor to install your TBI if your going to keep it injected. Might want to check if the 350's got bigger injectors than the 305's back in the day. It'll start/run drive with the 305 injectors/ecm... just migh be a touch lean on the top end.
~Scott
Old Nov 30, 2007 | 01:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TBI forum is the place for all of those details.
Old Nov 30, 2007 | 01:57 PM
v10viper04's Avatar
Engine: LT1, L99
Re: L03 to L05?????
this started as a swap question..... not a tbi question.... but thanks anyways
Old Dec 2, 2007 | 09:16 PM
v10viper04's Avatar
Engine: LT1, L99
Re: L03 to L05?????
is the L05 a good motor? are there any problems i should watch out for?
Old Dec 2, 2007 | 11:43 PM
five7kid's Avatar
I understand it's a swap question. What you need to understand is the best information about 350 TBI swaps is on the TBI forum.
I know of a few LO5's that had rod bearing problems. Also know of a '94 with over 250k miles on it, never been opened up.
Old Dec 4, 2007 | 10:08 PM
v10viper04's Avatar
Engine: LT1, L99
Re: L03 to L05?????
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
anesthes
Sep 21, 2015 10:24 AM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
