VATS Question
Old Dec 1, 2007 | 08:17 PM
JoeyG's Avatar
Car: 68 Chevelle w/ TPI, 87 Formula 350
Transmission: 700 R4
Axle/Gears: 3.55 / 3.42
VATS Question
Hey guys, I have a question about the VATS system. I just did a TPI swap into a 68 CHevelle. When I tried to start it, it wouldnt start...it just cranks. I had a spark but it looks like no fuel is entering the engine. I have pressure in the lines and rail, but nothing in the cylinders. The engine is from a 1990 GTA. My question is about VATS. I bought the engine from a wrecked car. When I pulled the door on the ECM it had a hypertech chip in it. I was told that aftermarket chips do not support the VATS. Ironically, the engine wont start, and it appears that I have no pulse from the injectors. Do you think I need the VATS bypass even though I have an aftermarket chip. Anyone else ever run into a problem like this?
Old Dec 1, 2007 | 08:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There's a good tech article on VATS linked from the thirdgen.org homepage.
Old Dec 1, 2007 | 08:55 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: VATS Question
I have a TPI specialties speed density prom for an L-98 with vats delete if you interested.
Old Dec 2, 2007 | 06:50 AM
JoeyG's Avatar
Re: VATS Question
in response, I know exactly the way the VATS works. My question is does an aftermarket chip eliminate the VATS coding? I was told it does but it seems like thats the problem. Everything else is working fine. I didnt look into it too much after it didnt start because it was getting late. I have a VATS bypass module but thanks anyway.
Old Dec 10, 2007 | 09:21 AM
fbodyguy86's Avatar
Car: 92 camaro rs
Re: VATS Question
all the hypertech chip does is alter timing curves i believe the vats is programmed into the computer or you could burn your own chip to disable the vats but the bypass module is the easiest way to go
Old Dec 10, 2007 | 09:54 AM
JoeyG's Avatar
Re: VATS Question
fyi, it was the bypass module...no big deal...thanks
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
