305 to 350
Old Dec 9, 2007 | 03:13 PM
lanmankilla's Avatar
Car: 84 Z28
Engine: LG4
305 to 350
If I wanted to take my 305 out and replace it with a 350 from the 60s or 70s, would the transmission still shift the same? Is there anything else I would need to know that I'll have to change for this swap? The car is a 84 Z28 LG4
Old Dec 9, 2007 | 07:57 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 305 to 350
The transmission shifts are decided by how your TV cable is adjusted. If you re-use your intake and carb, the way it is set now shouldn't change.
If you are running a different setup then you will need to re-adjust your TV cable to make it shift properly. Your repair manual will tell you how to adjust the cable.
Old Dec 10, 2007 | 02:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you run the LG4 ignition/induction system (only sane approach for a street driven car, IMO), then all you have to do is properly adjust the TV cable when you reinstall. Adjusting the shift point/behavior with TV cable adjustments is an absolute no-no.
If you don't use the LG4 carb, then you have to make absolutely sure the cable, bracket, and lever geometry exactly matches the q-jet configuration, or you'll be buying transmission after transmission.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
