Finished 350 build picture
Car: 1987 Z28
Engine: 355
http://img405.imageshack.us/img405/4756/350beastkc8.jpg
Just got it finished and about ready to swap into car
Car: 1987 Z28
Engine: 355
Re: Finished 350 build picture
The engine is a 2 bolt main 30 over. A set of aluminum cylinder heads 190cc with a 64 combustion chamber. Cam has a lsa of 110 and the lift is 508 intake and 512 exhaust. Performer intake, roller rockers, nice set of forged srp flat top pistons makeing around 10.5 to 1 compression. cast rods and crank. Im shooting to make aroung 360-370 hp.
Transmission: 4L80E/4L80E
That's the first time I've seen a 12 o'clock bolt-on timing tab.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
How do you actually time it with the timing tab at the 12:00 position.. With it at the 2:00 I fully understand it.. What would you have to do different to the crank to put your timing tab there? I do know that it would be harder to time as the waterpump would be sitting directly over where you need to look.
Many SBC's in the late-70's to mid-80's had the timing tab at 12 o'clock. I've seen it as early as '78 and as late as '86.
The only difference is the mark on the harmonic damper.
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I noticed the 12:00 timing tab right away as well. Where did you get it? I could really use one of those.
The engine looks great. Nice work.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
good old chevy orange never fails! looks nice! motor swaps are lots of fun, wish i knew four years ago what i know now! coulda timing the motor and tuned the carb myself with ease.
colton_carlson
Mar 8, 2019 12:21 PM
Linson
Aug 21, 2015 02:12 PM
I'm with you! Never seen that before...
